Facing a problem in writing textfile, badly need help.
Ok. Without knowing what exactly you are doing and just blindely folowing what you previously had, I put something quickly for you together. Your measurements will continue untill you press the stop button. It will then save anything it has gathered in a text file once its done. As someone mentioned above, you can save individual points as its measuring by placing the save function inside the while loop.
Kas
Message 11 of 14
(721 Views)
is it possible if you could printscreen for me your program that u attached?
i can't seem to open it because i'm using Labview 2011.
Thank you so much in advance.
Message 12 of 14
(701 Views)
Saved for 2011 version.
Message 13 of 14
(696 Views)
Thank you! Is there any way where i could just not use sub vi?
and the next thing is that is it possible for me to log the time of the data as well.
Message 14 of 14
(684 Views)
