Facing a problem in writing textfile, badly need help.
I am already close to finishing this. Just that the problem i'm facing is that i can't seem to log the data into the textfile.
It says that the concatenate has an error or something. That's the problem because i can't seem to find it.
Do i have to use "Format string" to convert the numbers to string first? Because i've tried it before, it can't work too.
Please help. Thank you in advance.
Message 1 of 14
(3,979 Views)
Where is the concatenate function you say is causing an error?
Yes, you need to convert the number to a string to be able to write to a text file.  (I don't understand the number to boolean, to 0:1 dance you are doing in there.  What was the point of that?)
If you have a problem with converting a number to a string like you said, then post a VI that show that attempt.
Message 2 of 14
(3,976 Views)
why are you using 2 loops? you can write to file in the same loop....
Message 3 of 14
(3,968 Views)
I want to write the datas into 2 separate files.
Message 4 of 14
(3,953 Views)
that's fine, though you do not need 2 loops to do so....and it looks like you have data flow dependent loops
Spoiler
Message 5 of 14
(3,948 Views)
@apok can i know what do u use fr the one beside "open/create/replace file?"
Message 6 of 14
(3,924 Views)
You can use write to spreadsheet vi. It may be simpler. Just convert your output into 1D array.
Message 7 of 14
(3,912 Views)
I actually want it to be a raw data. Thats y i need to put them in a textfile
Message 8 of 14
(3,905 Views)
What do you mean by raw data.
Message 9 of 14
(3,902 Views)
Can i know what function do u use for the HumidityTextfile.txt? and i want the data to be logged continuously.
I tried editing and it only log 1 data and that's it.
Message 10 of 14
(3,876 Views)
