03-29-2011 01:42 PM
My own issue is with the Display State Change, which is fired when the XControl is loaded, even though the comments in the facade template don't indicate that it should be fired in that case. One idea I have now, based on your latest post, is to use the First Call? primitive and only set the state changed boolean if it's false. This should presumably handle the case where the control is loaded, but I would have to check that. I'm assuming this should probably also work in Tim's case.
03-29-2011 01:45 PM
That's similar to the workaround I added earlier in this thread where I just ignore the events if they happen when the owning VI is not running.
03-30-2011 06:24 PM
Hi Tim. It seems like for now, the workaround is the best solution. I know that it's not ideal, but it does prevent the hassle of having a dirty VI.
