09-28-2016 09:33 AM
I have been trying to get 30fps with a Grab and Save to AVI .vi with a Greypoint camera over GigE. I have tried both with the LabView example and with the ring buffer example (https://decibel.ni.com/content/docs/DOC-39157) & (https://decibel.ni.com/content/docs/DOC-36471). I am using MJPEG to compress the file in AVI Create. I have used both AVI and AVI2 vi. Using the example code to read the buffer number I can see that I am acquiring at about 45fps and processing at an inconsistent 20 fps. No matter what I do I can’t increase the fps. I believe that with the Grab and Save, the frames are getting over written before they get a chance to be processed. So using a producer consumer loop should fix that, but it doesn't increase the fps. I know that IMAQ produces a pointer and is not actually queueing the actual image, but I found a code that puts the whole image into the queue, and that didn't seem to help either. Appreciate any help, I'm stuck.
09-28-2016 09:51 AM
-What camera you are using exactly?
-What is the maximum fps of camera?
-What is the resolution you are trying to acquire?
-Can you post what you tried?Is that the same example?
-So only acquiring you are able to? If not i would first do that experiment to ensure you can acquire at the frame rate you require and then go to processing section.
09-28-2016 09:57 AM
Camera data sheet is attached. It is capable of 120fps. I will be cropping the image but for now would just like to be able to record at 30fps for full resolution. I know that I am aquiring at 45 fps based on IMAQdx buffer number example which I will attach when I get back to the lab in an hour.
09-28-2016 10:11 AM
09-28-2016 10:12 AM
It is USB I was incorrect
09-28-2016 12:04 PM
This is the code that I modified from the original example Save to AVI example built into Labview. I added the code from Grab and Detect lost buffers. This allows me to see the see the acquired frame rate and the processed frame rate. I added the additional code CirImBuf which supposedly takes the images from IMAQ Create Vi and saves them to a circular buffer. This should be saving the images directly as opposed to just saving the pointer to a buffer. Adding it had no change on the fps processed over just having IMAQ create in line directly.
09-28-2016 12:21 PM
This is the code that I used to try and add a ring buffer to the code. I can’t use the code to get the acquired and processed frame rate anymore but I know it’s less than 30 because I was recording a stop watch. I modified the code by first removing the excess processing I didn’t need. I then added the cirimbuf instead of the for loop. Neither would increase the fps noticeably
