FPGA target. help with sbrio 9631
Accepted by topic author Defested
I think I see the problem. You have ModA (9205)  and ModB (9263) are located under your Chassis, while his are located under his FPGA target. If you drag the modules down to  under the FPGA target, you should be able to add the IO to your project.
Cheers!
TJ G
Message 11 of 17
(1,610 Views)
The NI 9205 and 9263 are called modA and ModB. How do i add them so that i can use them with the fpga?
Message 12 of 17
(1,606 Views)
TREX, good catch...(taking my blinders off).
TREX had the answer, just drag them under your FPGA target (don't forget to save the project).
Message 13 of 17
(1,606 Views)
Sorry for so many questions. But when i try to add them to my vi, I get a broken run arrow. How do i implement this to use the data recieved from the input?
Message 14 of 17
(1,602 Views)
What errors are listed when you click on the broken run arrow?
Cheers!
TJ G
Message 15 of 17
(1,596 Views)
Here is the error message from the broken run arrow
Message 16 of 17
(1,593 Views)
I fixed the broken run arrow, I am getting data now. Thank you for all your help.
Message 17 of 17
(1,587 Views)
