FPGA power up state
Hi, How can I set the powerup state for 7811R card. I tried by running a initialization bitfile before running my application. It sets the default states, but when I run any other bitfile, the states are again going to High Impedance. I have used 'Close' option instead of 'Close and reset' in the host code. For Ex: First I run the initialization Bitfile_1, in which I have made the state of DIO0 to 10 as FALSE. Now, I run Bitfile_2, in which I am changing the states of the DIO12. But on doing so, the state of DIO0 to 10 are again going back to High impedance. In both the host VIs, I have used ' Abort and Close' option instead of 'Close and reset'. The host code is attached. How can I restrict the DIOs from going back to high impedance state if not in use???
Message 1 of 1
(2,400 Views)
