FPGA not writing voltages correctly
I am using a cRIO 9035 with modulus NI 9264, 9205, 9213, 9401, 9344 x2.
Here is what my FPGA code looks like:FPGA.pngAs you can see the "Tube_Air_MFC" is wired to AO2 and the "MFC_Tube_Air" is wired from the AI2. I attached the current project that I am working in, if you run the initialized values you will see that the Air Set value will read  ~14.37 which will correspond to the flow rate of the tube air. FrontPanel.PNG
It should be outputting 14.37/15 = 0.958V, instead though my multimeter is giving me a reading of 0.331V. Since my analog output is wrong then the analog input is wrong too, so the actual air value is completely off.
Sticking with the same analog device, I am using a SmartTrak CL100 mass flow controller at the AO2 position. It has a voltage reading of 0-5V and a flow rate of 0-75 SCCM, hence the voltage conversion of dividing/multiplying by 15. The NI-9205 terminal is set to +/-5V with a differential terminal.
Here is what the wiring looks like
I kept getting phantom voltage readings from the NI 9205 so I just grounded all the terminals that were not being used.
Message 1 of 10
(5,460 Views)
Anybody have any clue? I tried setting a larger wait time, but that didn't seem to do anything
Message 2 of 10
(5,424 Views)
What does the output rad with just a meter connected and no load connected?
Ben
Message 3 of 10
(5,419 Views)
Ben
If there isn't any voltage being sent then the readings are small decimals (i.e. below +/- 0.25)
Message 4 of 10
(5,414 Views)
@atokad wrote:
when;
Ben
Message 5 of 10
(5,412 Views)
It was ouputting 0.331V whenever the calculation should've been 0.958V.
Now since I changed the wait time, it looks like there is actually 0 voltage output.
Message 6 of 10
(5,401 Views)
I am headed home in 14 minutes...
If you do what I asked before then I may be able to help further but after that you willhave to forget about me being able to help.
Run the code again "whenever the calculation should've been 0.958V. " do not mess with anything else except pulling wire off of the terminal block.
12  minutes now.
Ben
Message 7 of 10
(5,397 Views)
Which wire on the terminal block? Are you referring to the module or the code??
Message 8 of 10
(5,393 Views)
the physical wire get disconnected and attach a meter where the wire was connected.
There could be an issue with the load you are driving...
Ben
Message 9 of 10
(5,384 Views)
That gives me a voltage reading of .290V
Message 10 of 10
(5,382 Views)
