09-05-2017 12:10 PM - edited 09-05-2017 12:10 PM
System:
LabVIEW 2011 SP1
Xilinx 12.4 SP1
I'm working through this white paper on FPGA compile farm setup ( http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahelp/fpga_gettingstartedfpgacompilefarm/ )
In the section titles Setting Up the Compile Workers, I can do everything except for step 3. When I login into the compile server, I don't see that FPGA Compile Farm Console button. Even though I'm compiling locally, shouldn't this option be available if I have the correct software installed? What does this mean if I don't see it on there (what do I need to install)?
Thanks in advance.
09-06-2017 07:01 PM - edited 09-06-2017 07:01 PM
Hi sjacksonPA,
Did you see the button that had that icon or one similar to is on the page after logging in to the compile server?
It might be a little subtle but I believe it should be there on the login page.
David
