FPGA based FFT analysis - array?
Highlighted
hi
How can I analyze the spectrum given by the FPGA-based FFT, within the FPGA?
The "analysis" here can be for example to calculate the integral of the spectrum in a given window of frequencies (a sort of lock-in).
I can do it in the host, using a FIFO for the transfer and analyzing the array (of 8132 points) which comes out of the FIFO in the host. But is the same possible in the FPGA? Can I put the output of the FFT into an array and analyze it without leaving the FPGA? Or should I follow a different strategy?
The project requires to calculate the spectrum of an input signal, to analyze it, to feed a PID with the result of this analysys, and to send an output signal from the PID. Therefore speed is important and all should live in the FPGA.
(1,209 Views)
Highlighted
Hi fpdx,
Can you send us your project/VI or screenshots ?
Have you tried to use a target-scoped FIFO in your FPGA ?
Samir
Ingénieur d'applications
National Instruments - France
(1,153 Views)
