12-06-2018 01:12 AM
Hello.
I have a problem that is i had a project which is request FPGA analog input module(NI9215 0-10v),the module is configed with calibrated mode,there is a pressure sensor(0--10bar)connecded to this module.When draged this channel to VI to get the pressure which i wanted but it only show the voltage value,my question is how to programm the code to get the pressure instead of voltage. Is there some stand function can do this?
By the way i am a rookie for Labview
Solved! Go to Solution.
12-06-2018 08:42 PM
I think you would need to do a conversion from Voltage to Pressure like something in this forum post: https://forums.ni.com/t5/forums/v3_1/forumtopicpage/board-id/170/thread-id/831441/page/1
Here are some other links which you might find useful:
https://forums.ni.com/t5/LabVIEW/Pressure-transducer-NI-9263-and-NI-921/td-p/3697765
https://www.youtube.com/watch?v=spTHTfjVlo8
12-06-2018 11:43 PM
12-07-2018 09:37 PM
Hi There.
Thanks for the reply
what i need is:is there a stand function in Labview Library i can use?
Actualy i sensor range is from 0--60bars
What about the analog module configration,should choose raw values or cailbrated value?
12-07-2018 10:35 PM
12-07-2018 10:51 PM
Hi GerdW:
Do you have any sample of the analog input scale VI?
My Labview version is 2016 sp1
