07-02-2018 04:53 AM
Hi all!
The following problem during analog output generation on NI-USB 7856R is encountered:
When trying to generate a voltage ramp, one datapoint seems to be significantly lower than the previously generated or the next datapoint. (see attached figures). The generation itself is done via DDS from an example found on this forum (http://www.ni.com/example/31066/en/).
I think it’s a glitch or “single point excursion" ?
I tried to narrow down the problem and supplied a minimalistic VI. Here, a sawtooth ramp is generated via a NI example for DDS. Additionally, also a sine via expresss vi with 10Hz is included for comparison. Both signal exhibit this glitches…
What is your impression of this problem? How can it be avoided?
HM
08-02-2018 02:50 AM
Hi CTA_TUW,
did you manage to find out solution to this problem or at least explanation?
I am really curious why it is happening.
09-19-2018 08:17 AM
Hi Maciej_B!
Sorry for the late reply...Well, it seems there's no quick solution for this glitch problem:
I may quote from Texas Instruments (http://www.ti.com/tool/TIPD142😞
"DAC R-2R architectures display great performance in regards to noise and accuracy, but at a cost of large glitch area".
The only possible solutions for reducing the glitches when more than 3 significant bits change from 0 to 1 (or vice versa), is to use a track and hold (T/H) circuit as proposed by the TI source.
The only thing bothering me is that NI doesn't implement a built-in glitch reduction circuit in the first case...regarding the feasibility of a simple T/H circuit...
Best Regards!
09-20-2018 07:56 AM
Isn't track & Hold for the input side, not the output side?
These glitches are occurring at your Output stage, you will see them on an scope attached to your device.
There are ways of compensating but they require active calibration and are temperature-dependent. i.e. there's no easy way to have a one-off fix for this behaviour. I know this because we do exactly that with our hardware and it's not a trivial thing at all.
Shane.
09-21-2018 02:57 AM
Hello Shane!
Yes you're right, basically T/H is mostly known for the input side - but if you happen to reproduce the switching conditions for the "hold" state you should be able to buffer the glitches before reaching the AO stage. At least that's the possible remedy as proposed by TI (http://www.ti.com/lit/ug/tidu022/tidu022.pdf).
I'm very curious about your method for the glitch reduction of R2R DACs. Maybe you are willing to share some insights?
Best regards!
09-21-2018 03:17 AM
Can't share, sorry. Proprietary.
The design you linked to (via PDF) does have other effects on the output, bandwidth, slew rate and so on. It's not a magic bullet.
09-21-2018 03:48 AM
Hello Shane!
Unfortunately there's never a magic bullet...
So I'm patiently waiting for the first Gray code DAC from NI (or some other market player) to appear...
09-21-2018 04:13 AM - edited 09-21-2018 04:14 AM
Does grey encoding even work with DACs?
Hmm, quick google search, apparently it does. Interesting.
