FPGA Compile Worker Crashes When Trying to Compile FPGA Project
When I try to compile my FPGA project on LabVIEW, I get the following error message.
Due to bad installation or configuration, the compile worker does not have any compile
capability. Please fix any issues and restart.
I had gone through this website https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019XdISAU&l=en-IN as I am beginner in FPGA, I am not able to understand how to solve this error
please provide detailed explanation.
Thanks in advance.
Message 1 of 9
(4,350 Views)
What hardware are you trying to compile for, what LabVIEW version are you using, and what compile tools have you installed?
Message 2 of 9
(4,326 Views)
I am using myRIO, LabVIEW 2018 along with myRIO Toolkit, LabVIEW Real time module, LabVIEW FPGA 2018, Xilinx compilation Toolkit for Vivado 2017.2
Message 3 of 9
(4,324 Views)
Did you get any progress on the error fixing? I had the same error with you. My environment is
SBrio 9627
LabVIEW 2018 32bit
Real-time 2018 sp1
FPGA 2018
NI compactRIO driver 18.5
Xilinx Compilation Tool for Vivado 2017.2.
It told me to activate the "NI application web server" in PC service, i did that without any effect.
Message 4 of 9
(4,284 Views)
yes, i had solved my issue. Try to download LabVIEW software platform Bundle Spring in that select LabVIEW, Real-Time Module, FPGA Module, myRIO Toolkit, FPGA Compile Farm Toolkit, Xilinx FPGA Compilation Tool for ISE 14.7 or Xilinx FPGA Compilation Tool for Vivado 2017.2.
http://www.ni.com/en-in/support/downloads/software-products/download.software-platform-bundle.html#3...
in my case i had downloaded LabVIEW software platform Bundle Spring 2018.
but now it is locked. 2019 is available try to download it and install. check you have solved the issue or not. please post if you solved or not it will be useful for further readers.
Message 5 of 9
(4,273 Views)
This error happens because of Software incompatibility. i think
Message 6 of 9
(4,267 Views)
Thanks!
I'm downloading the platform bundle, one more question, did you uninstall everything of NI before installing the bundle?
Message 7 of 9
(4,265 Views)
Yes, I had removed every thing from package manager
Message 8 of 9
(4,261 Views)
My issue fixed as well, it related to the OS system, i changed the laptop and installed the software as before. It works.
For the software platform bundle 2019, it didn't include the Xilinx FPGA Compilation Tool for Vivado 2017.2.
2018 is full of software, but it's locked now.
Message 9 of 9
(4,246 Views)
