04-13-2007 10:18 AM
04-13-2007 10:43 AM - edited 04-13-2007 10:43 AM
Message Edited by nathand on 04-13-2007 11:50 AM
04-13-2007 11:03 AM
OK, I see.
I was able to get the Test Remote running on the RT and it is spitting out data on the RT com port.
Now then, what I seem to still be missing is the fashion in which to communicate the message string from the local computer to the RT.
The VI running on the RT should be constructed to lie dormant and wait for a string to be sent from the local host, then activate and write it out.
How does one do this?
04-13-2007 01:00 PM
04-13-2007 01:05 PM
04-13-2007 01:23 PM
Well, now I get this error:
Deploying FP @ 172_30_3_107 (successfully deployed target settings)
Deploying RT Network Communication.lvlib \\172.30.3.107\RT Network Communication deployment failed (error: -2147220717, (Hex 0x80040313) The Remote Procedure Call connecting the client to the configuration server failed to be initialized. Your installation may need to be repaired.).
04-13-2007 01:41 PM
At least the code example is clear and simple.
04-13-2007 01:48 PM
04-13-2007 02:10 PM
That was the problem casuing the error alright.
Neither the Network Variable Engine nor the Variable Client Support were installed on the RT.
Now the software deploys with no error.
However, it doesn't run.
I receive no data on the host.
I have to click on the remote VI in the project and open it.
It isn't running, and I click the Run button.
Then data is received on the host VI.
I tried changing the Execution properties of the VI to Run when opened, but that didn't help.
We're real close here.
04-13-2007 02:19 PM
