Using the Labview communications VIs, I'm attempting to run UDP and TCP/IP
through a Fore Systems PCA-200E ATM network interface card on an NT 4 service
pack 5
machine. I can't seem to communicate with the ATM card even though I have
the
ForeRunner PCA ATM adapter and the ForeRunner IP Over ATM Adapter drivers
installed.
I've tested my UDP and TCP/IP VIs successfully using a 3Com Ethernet NIC,
but the
Fore ATM card won't respond to the Laview VIs. I know the ATM card is good
because it works with commercial software written to access the card
directly.
Why can't I communicate with the Fore ATM card using Labview?
