09-06-2017 03:50 AM
hi every one, i have written a program for FM TX in labview block diagram. but this program throws a error of 4810. which i tried in many sound file formats such as wav, mp3, amr etc,
hardware is usrp 2901
here i attach a image for it.
kindly reply
09-06-2017 03:57 AM - edited 09-06-2017 03:58 AM
Hi Kashizudoto,
This error has an explanation text: "Cannot recognize sound format".
Well, the function you use only supports WAV as is written in the help for this function.
Additionally not all different kind of encodings in the WAV file are supported - as is also written in the LabVIEW help!
Can you attach your WAV file here (atleast a smaller one, packed in a ZIP file)?
09-07-2017 01:10 AM
@GerdW wrote:
Hi Kashizudoto,
here is the wav format sir,
do it run the program?
09-07-2017 01:19 AM - edited 09-07-2017 01:25 AM
Hi Kashizudoto,
your WAV file is using a very unusual sample rate and some compression.
As the LabVIEW help (do you remember?) mentions, compressed WAV files aren't supported…
See this analysis result for your WAV:
("proprietory format 55h")
Compare with a standard WAV file:
On your VI: unfortunately you are using LabVIEW-NXG and I haven't installed that one yet.
09-07-2017 06:15 AM
sir, i have used another wav file and i accept u r solution,
but i run the program with highlight execution it says labview memory is full.
i have attach the zip file for u kindly take a look
09-07-2017 06:25 AM
Hi Kashizudoto,
no need to put all (smaller) files into ZIPs. Only those bigger (WAV) files are easier to up-/downlad when packed as ZIP…
On your error: the error is generated in the Resample function.
As I don't know the size of your WAV file nor the settings you used for resampling I can only say: there surely is a reason to give that error message…
