FFT image registration fails for multiples of 8
I notice actually now that the first element in the matrix at position (0,0) for the 16x16 matrix is 0 + 0i.
Then doing division by zero leads to NaN. Putting a matrix with one value NaN into the inverse FFT method gives out an array of NaN.
I guess I'll just replace the first element in the array at position (0,0) to some non-zero value and it'll work. I don't really understand why this is the case.
Message 11 of 13
(547 Views)
Why don't you simply use the 2D cross correlation?
(Here's a very rought draft. probably needs quite a few tweaks) 😉
Message 12 of 13
(539 Views)
You're absolutely right, but the whole pursuit was to compare the two with each other. See which one is faster or better for my set of data and if I can do things better than NI.
Another objective was to put the algorithm on the FPGA.
Message 13 of 13
(531 Views)
