02-14-2010 02:33 AM
Hi
I'm getting this error everytime i try to run a program.what exactly does it mean and what should be done to avoid it??
Thanks...
02-14-2010 08:53 PM
Don't run the program, then you'll never see the error.
Seriously, you are going to have to give some real information. What does your program do? Does it do anything special such as interact with ActiveX controls or other external objects?
02-15-2010 05:56 AM
Hi
thanks for your reply.I have not used any active x but i read the excel sheet continuously (after every 1 second).
02-15-2010 10:07 AM
02-16-2010 03:50 AM
ok
so what is the solution??
02-18-2010 10:35 PM
02-18-2010 11:32 PM
02-18-2010 11:45 PM
Hi Shreyas
Thanks for your reply.please find the image attached here.
02-18-2010 11:47 PM
02-19-2010 12:05 AM
transact.cpp
Seems to me as an internal LabVIEW bug. This is the .cpp file (C++) which is not executing as expected, causing LabVIEW to crash.
The same kind of error "memory manger.cpp" caused LabVIEW to crash in my case.
