Beginner here - Does anyone have any ideas on what would be the easiest way to create a function that would essentially perform the same function as the built in "Extract Single Tone Information.vi" only that instead of using Hanning windowing I would be able to use Flat Top (or selectable windowing)? I basicly need to set something up that will accept an incoming Sine wave and apply Flat Top windowing then output the measured frequency and the amplitude of that frequency. I need to still be able to input the "advanced search" criteria into the VI and give it a frequency and tolerence to look for as I don't want to just look for the peak signal but at specific frequencies.
