Hey West Coast,
If this driver is not working properly then unfortunately there isn't much that can be done. This driver is not supported nor maintained by National Instruments or a third party (as stated on the
download page). I would recommend either using the VISA vi's instead or contacting Rod-L to see if they have a Labview driver for this device. If you decide to try unsing the VISA vi's you will first have to download and install NI-VISA (latest version found
here). Go to Labview's example finder for examples on how to use the vi's. Then you will need the instrument's commands. These can usually be found by either looking in the instrument's manual or by contacting the manufacturer.
I hope this helps in getting you started!
Jason W
