07-07-2009 08:22 AM - edited 07-07-2009 08:26 AM
07-07-2009 09:19 AM
Trying to create more than one task for AI the same time result in the encountered error message....This is because AI can only have a single sample clock source. Due to device access, this is a prerequisite for a single device. Having more than one DAQ device will enable you to define two different clocks for the two devices.
hope this helps,
Norbert
07-07-2009 09:26 AM
07-07-2009 09:28 AM
Correct.
But if your external clock is faster than your internal (and constant!), you can sample both channels using the external clock. You might have to reduce the readings from the first channel, which should be sampled using the internal clock....
hope this helps,
Norbert
07-07-2009 09:38 AM
