02-06-2019 10:33 AM
I am making an express VI for a dialog box. When I configure it, most settings are not "sticking," i.e. I set them, hit OK, and the Configure panel closes. When I try to run the VI, the changes I had made are not there, and re-opening the Configure panel, shows most changes are not sticking. A previous iteration of this worked fine, as do similar Express VIs. Attached is the VI in a package that can be installed to LV2016 and later. The only control that sticks is "Scale." All others do not.
Any help would be greatly appreciated!
02-06-2019 12:36 PM
If it is just the VI, with the Dialog Box express VI, you can just attach that.
As for your problem: Which settings are sticking and which get reset?
02-06-2019 01:02 PM - edited 02-06-2019 01:09 PM
The only control that sticks (works correctly) is "Scale." All others do not.
Attached are the VIs, not in a package.
02-07-2019 02:03 PM
I have created an Express VI from a VI. I've spent the time to arrange my Configure Panel. Now I made changes to the original VI. How do I update my Express VI without re-making the whole Express VI?
02-07-2019 04:29 PM - edited 02-07-2019 04:29 PM
I think you are the first person I have ever come across to say they were making their own Express VI. I knew it could be done, but it always seemed like it would be a lot of work to create. The intended audience for Express VI's seems to be limited and is for people who want to write a program, without really trying to program.
Good luck!
02-07-2019 04:41 PM
It is not to bad to create one, but a huge pain it the @$$ to make changes. I never would use one, normally, but I made some specialty dialog boxes for someone else to use, so they could easily configure message, size, buttons, colors, etc.
