I use the "Export waveforms to spreadsheet file" vi in order to... export some waveforms to a spreadsheet file !
I wired a "true" constant to "Append to file ?", and I noticed that it skip a line between two acquisitions. I wanted to know how I can avoid that, and write the data right after the previous one. I could just delete the empty lines with Excel, but for very long acquisitions it won't be very convenient.
I was afraid this was the solution of my problem, I'm not used to modify VIs directly. I tried to find the thing to change, without success for the moment. And "Export waveforms to spreadsheet file" uses an old version of Open/Create/Replace file so I will have to change this.
I had this same bug today and had to edit the "Export Waveforms to Spreadsheet File" vi. In the "Generate Formatted Data" loop, the last Y values were always empty. I added the code in Bug Fix to remove that last column and now I don't have empty spaces in my excel files.
