05-14-2019 12:14 PM
@Zaqf wrote:
Since I'm using compactrio 904x I won't be able to save it on my PC or desktop. Where do I save it ? Any idea ?
Of course not. The cRIO is a completely different computer from your desktop.
This seems like the first time you ever mentioned a cRIO!
05-14-2019 12:16 PM
Yea. It's been so many days I've trying to sort this out , please help me find a file path as well, I need a waveform graph of one of the AI channel , buh when I connect the the graph, I'm getting the graph of both the channels with single plot.
05-14-2019 12:20 PM
Use an index array to get out whichever of the two channels you want.
Since your data is equally spaced in time, you could use a waveform graph if you have the whole data set of values, or a waveform chart which allows you to add a data point at a time since a chart maintains a history of the data that came before it.
05-14-2019 12:22 PM
05-14-2019 01:06 PM
Is it okay if I just connect a pen drive to the Crio device , and copy it to them ?
Thank u.
05-14-2019 01:15 PM
05-15-2019 04:24 AM
Index array connected before the first built array yeah ? And then connected to the graph ? Could you please enlighten me in detail.
Thank you
05-15-2019 04:33 AM - edited 05-15-2019 04:34 AM
05-15-2019 04:33 AM
I can't work out which VI you're currently using (the most recent "daqmx latest model MOD.vi" has no graph, and uses random numbers to create the results), but it seems very likely that if you use Index Array before the first Build Array, then you won't have an array and it won't produce a valid run arrow.
Probably using Index Array immediately before the current graph (guessing) is what was intended.
05-15-2019 04:37 AM
Yes , it is the same VI. I've connected the channels instead of random numbers and I just need a graph of one of the channels.
Please help.
