Export to excel from express VI table is not working
Why not?  I was able to.
What is different between your code and mine?
Show your code.
Did you try downloading the image and dragging the PNG file into your block diagram?
Message 21 of 64
(166 Views)
Could you tell me as which file u save it ? Coz I wasn't able to save any data that I got.
Message 22 of 64
(161 Views)
What is "coz"?   What is "u"?
I don't know what you mean by "which file I save it".
Your array indicator should be 2-D.
You forgot to wire a constant going into the left hand shift register.
And I made a mistake on my program.  The right hand shift register should have come from the 2nd build Array, not straight across.
daqmx-2_BD
Message 23 of 64
(153 Views)
I've got some legit data.  But still the main issue stays , I'm not getting them saved to my file directed. Here is the vi.
Message 24 of 64
(145 Views)
Highlighted
You must be getting something saved into the file.
Did you use the debug tools available such to you as probes to understand why yours isn't working?
Mine did get stuff saved to the file, but I found out I needed it was missing the "i" time because I pulled the data from the wrong wire.
Also, you had an extra True constant in there that transposed the array.   When I removed that, the CSV file looked correct when opened in Excel.
Message 25 of 64
(135 Views)
Thank you so much.
Right now I'm not in the workplace , buh tomorrow I should get the data copied. So could you tell some of the reasons for the copying not to happen so that I can check all of it .
Message 26 of 64
(131 Views)
Issue prevails , the data is not appearing on my excel.csv or notepad.csv. cannot figure out the issue.
Message 27 of 64
(106 Views)
I'm looking at your "daqmx latest model.vi", and although you won't get any "time" data because the wire going to the Write Delimited... VI is before you append the "i" value, I don't see another problem.
Try connecting an Error Indicator to the output of the Write Delim VI and see if it give you any clues. Is the file created successfully?
Message 28 of 64
(102 Views)
Error indicator has a green tick , the code is 0 and there is nothing in the source column.
Message 29 of 64
(100 Views)
Now I've got an error in the indicator , code 43 , saying " open/create/replace file in write spreadsheet string.vi->write delimited spreadsheet(DBL).vi->Daqmx latest model MOD.vi
Message 30 of 64
(97 Views)
