Online shopping is currently unavailable.
Please contact us for help or try again later.
Export simplified image, still confused
I really want the output of an X-Y graph in a vector based graphics format (needs to be resized etc). I have been using the export simplified image from data operations menu. Both .eps and .emf exports show the same behavior.
Only problem is when a plot has markers but no line or i set the color of the line to be transparent, the marker color turns to black in the output. If the the line is present then the marker color is fine too. Ideal would be to have a graph with color data markers but no lines.
I made a test to show what I mean.Theres some data in there to fill the graph with points when its run. My result is there too, had to be copied into powerpoint, .emf file arn't allowed.
I'm running LV 8.0 on WinXP, could anyone test this out for me and report results. I would like to know if I'm doing something wrong, or its something with LV.
Tim (LabRat1)
(3,042 Views)
Hey Tim,
If you use bmp you get the image you are looking for.  are you planning on using this information in another file or just to display?
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,013 Views)
Hi Adam,
Thnks for your comment, my apoligies for this thread as it is a duplicate. I reposted the question to give a better example vi and hopefully get a quicker answer.
The original thread has be replied to and the answer given, this is a version issue and has been fixed in 8.20.
Tim
(3,007 Views)
