11-12-2019 04:18 AM
Hi ,
I want to know if there is a methode to Exit the Current vi when OK button ="True" and open/Run another (i want the code to be set in the red box ).vi
11-12-2019 07:13 AM
Don't close the front panel, just hide it using a Property Node of the VI (Front Panel Window->State). If you close all of the front panels, your application stops running. So hide it instead.
11-12-2019 07:32 AM
You might be looking for "dynamically starting a VI". A would dynamically start B, and can then safely quit. Note that B needs an open panel or an explicitly opened reference to itself, or it will stop running.
