06-05-2009 11:48 AM
I have a sql query that run directly in the database but when I attempt to run it in labview using the create_parameterized_query.vi I and fetch_recordset_data.vi get the following error:
Error -2147217845 occurred at NI_Database_API.lvlib:Rec Fetch Recordset Data (R).vi->NI_Database_API.lvlib:Rec Fetch Recordset Data (CR).vi
Exception occured in OraOLEDB: Accessor is not a parameter accessor. in NI_Database_API.lvlib:Rec Fetch Recordset Data (R).vi->NI_Database_API.lvlib:Rec Fetch Recordset Data (CR).vi->
I've been using the tracer utility to try to see what the problem is but so far I haven't been able to figure out the problem. I have several other tables in my database that I'm pulling data from and this same structure and they run without any problems.
I'm enclosing my .vi
06-09-2009 10:34 PM
Hi montyponty,
According to a Google search it looks like error 2147217845 shows up a couple of times with Oracle databases. Does the following page offer any helpful suggestions:
http://forums.devx.com/showthread.php?t=47596
From which VI does the error originate from? Can you post the other code that does work so we have a comparison?
06-10-2009 11:48 AM
