01-15-2010 01:48 AM
I didn't use Labview for a very long time and I got problem to understand an error code
I made a Vi that send data to a excel template file using ActiveX
The data transfert is good
But when I tried to modify the chart from Labview (the size of the array pasted from Labview may change so the chart in Excel has to be modify from Labview), I got this message Error 97 : Null Refnum was passed in as input.
In the Example, I'm trying to add a new serie of values to the chart with the array sent from Labview
Does anyone have an idea to help me ?
The excel template file has to be in "C:\"
thanks in advance for your reply.
01-17-2010 10:53 PM
01-18-2010 12:56 AM
Thanks for your reply
I will try it and move the chart sheet after the data sheet
01-18-2010 01:23 AM
01-18-2010 02:17 AM
I find an other way to do what I want
It works fine now
Thanks.
01-18-2010 02:19 AM
08-12-2022 02:27 PM
Would you mind relinking this? I am having similar issues. Thanks!
