Example of Test Bench for multiple FPGA I/O items
I'm looking for an example on creating a Test Bench that simulates multiple FPGA I/O digital lines.
I've gone through the Creating Test Benches tutorial but it only uses a single I/O item.  Read I/O Item Name.vi is obviously an important part of this but I'm not sure how to structure the VI and assign the name (especially since things seem to get wired up magically for a single IO item).
Any pointers to examples would be greatly appreciated.
Steve
(3,948 Views)
Hi Steve,
What kind of hardware are you using?  Did you look in the NI Example Finder?  Which tutorial are you talking about?
Best,
Jeff S.
(3,917 Views)
In this case, NI 9401, but we will be expanding to cover several different module types
Yes.  There are two (in Labview 2011) returned with searching for "testbenches" that are very basic.
http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/test_bench_tutorial/
This shows how to use a Template from the "Execute VI on Development Computer with Simulated I/O" option on the Debugging tab of the FPGA Target Properties. The template covers a single input and it's not clear to me how to simulate more than a single input.
Steve
(3,908 Views)
Accepted by topic author maherhome
Hi Steve,
Do you mean multiple channels or multiple signals for each channel?  In the tutorial you posted, you can find the answer for each.
To create multiple channels, just repeat steps 5-9 in the "Test the FPGA VI on the Development Computer with a Custom VI" section for your inputs and steps 5-7 of the "Testing the Output I/O Item" for your outputs.
To create multiple test samples for a single channel, you can refer to "Testing the FPGA VI with a More Complex Custom VI" section.
Best,
Jeff S.
(3,873 Views)
You're absolutely right, Jeff.  I didn't give the example the due diligence it deserved.  Thanks!
Steve
(3,864 Views)
Awesome!  Good luck with your application!
Jeff
Jeff S.
(3,849 Views)
