03-18-2018 09:42 PM
Hi there,
I'm in the progress of learning about instrument control with LabVIEW by building a program for curve tracer. But I don't any idea where shall I start with. Would like to ask any of you have any example for Tektronix Programmable Curve Tracer 370A? A simple example for curve tracer would be pretty much helpful in my learning.
Below I have the driver I downloaded from the 3 party community but it's not certified by NI. So there is no example as reference.
Thank you very much.
Jason
03-19-2018 01:55 PM
Hi Jason,
That's an old instrument! circa 1996 - http://www.testequipmenthq.com/datasheets/TEKTRONIX-370A-Datasheet.pdf
Now there is an example in that libray. Its the last file in the list "Tek 370A ATE Demo.vi". It opens in LabVIEW 2017, so I think it might run just fine. Study that code, but if you decide to program the instrument yourself don't follow their example with stacked sequence structures! Use sub VIs instead.
Post your code here when you need specific help.
Good luck.
11-25-2020 07:08 AM
Does anyone have the LabView interface for reading data from the Tektronix 370 series curve tracer?
BR,
Mohsen
11-25-2020 07:22 AM
Do you have the "Tek 370A ATE Demo.vi" file that you ate referring to?
BR,
Mohsen
11-25-2020 07:26 AM - edited 11-25-2020 07:27 AM
Hi Mohsen,
Did you read the last message?
It says:
So download that library and open it using LabVIEW…
