Event structure dont get triggered on value change in string
here i need help   i designed  a program i cannot solve one issue  that i am changing value  at strings and event structure is not responding may be someone can tell me a new way to send values one by one
snecond ly i attached one .vi that explain all problems
(3,586 Views)
Writing to terminals will not create events. In case you require this, use the "Value (Signaling)" property of the control/indicator you are writing to.
Norbert
Norbert
Expert: Geometry
(3,581 Views)
I can't open your file but if you want to trigger the event for every letter one by one, you will need to change to a control (based on Norbert's comment) and right click the control and select "Update Value while Typing".  This is helpful if you want to force all characters to be uppercase/lowercase or if you want to filter out numbers, etc.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(3,543 Views)
thank u Norbert
event is working now but i need 1 change must complete all iterations in other
but here i have 4 iterations  i have 4 values in array 1 to take rms  and send to other array2 than i want to have array1 become zero and repeat the procedure when other value is obtained
(3,541 Views)
Accepted by deutchland
You have to put the event structure inside a loop.....
Norbert
Expert: Geometry
(3,506 Views)
