05-20-2015 01:09 PM
@CalLab_Mark wrote:
So you're saying this forum is only for programmers to learn from each other? USERS don't come here looking for programs?
Yes.
If you are looking for someone to write this program for you, they'd most certainly want to be PAID for it.
I would.
You can post your project at http://forums.ni.com/t5/LabVIEW-Job-Openings/bd-p/JobPost
You may get plenty of people from overseas willing to do the job for cheap.
05-20-2015 01:26 PM
05-21-2015 05:44 AM
It is what it is. We have about 40 Labview stations and most of them move around as needed and run workhorse programs as well as custom. Only one guy does the programming as a sideline to his main gig. I just keep track of the DAQ cards & calibrate them.
I wasn't looking to employ anyone to "re-invent the wheel"--I just wanted to know if it had already been done.
05-21-2015 06:14 AM
05-21-2015 06:31 AM
@CalLab_Mark wrote:
[...] My company has a huge investment in Labview [...]
@CalLab_Mark wrote:
It is what it is. We have about 40 Labview stations [...]
Your company has a huge investment in stations which were programmed in LabVIEW, not LabVIEW itself (regardless of licensing). This is exactly the type of misunderstanding (that the tools written in LabVIEW = LabVIEW) that leads to people putting "proficient in LabVIEW" on their resume.
Grrrrr...
05-21-2015 09:08 AM
If you need to connect standards to the equipment to be calibrated, it may never be completely automatic. That being said, the equipment may have internal calibration routines you can call programmatically that will walk you through a calibration. It might even have an external "Electronic" calibration kit that can be controlled from the internal calibration routine to make it totally automatic (except for the connecting and disconnecting of the standard, itself). It should be fairly trivial if you have a programmer's guide. You probably only need to send the command to calibrate and let the internal routines prompt the user.
If you have to calibrate cables and stuff, you will have to develop your own code. Which, while not being trivial, should be pretty straightforward, provided you know how to do it manually.
