10-20-2016 07:26 PM
I have LabView 2016 on my computer, which is only compatible to DAQmx 16, and I downloaded DAQmx 16 from official site, but the error below came out when I double click the DAQmx 16. Can any help me install this DAQmx 16. Thank you so much.
10-20-2016 07:44 PM
I don't understand "running DAQmx 16". DAQmx is a series of functions (an API) for communicating with a number of NI Devices. Can you attach the VI that you are trying to run? Be sure the attachment has the extension .vi (we need to be able to run it ourselves).
10-20-2016 07:52 PM
This looks like it's a message from trying to run the DAQmx 16.0 installer is that correct? If you downloaded it from our website there is an MD5 checksum under the download link which you can use to check if there was some problem downloading it from our site.
10-20-2016 07:58 PM
sorry for confusion, it's the DAQmx 16 installer, so it' should be "installing" instead of "running".
10-20-2016 08:04 PM
I have LabView 2016 on my computer, which is only compatible to DAQmx 16, and I downloaded DAQmx 16 installer from official site, but the error below came out when I double click the it. Can any help me install this DAQmx 16. Thank you so much.
10-20-2016 08:46 PM - edited 10-20-2016 08:46 PM
Don't create a new message with the same question. Your new message thread has been merged with the old.
10-26-2016 02:48 AM
I have the same problem. Have you found a solution?
10-26-2016 03:36 AM
Nevermind. I have found the solution myself.
In my case I used NI Update Service to install DAQmx 16 and it went without problems. I couldn't install it from the file alone.
12-20-2016 02:00 AM
this seems to be a Microsoft Issue, try the following:
regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft \WindowsNT\CurrentVersion\Windows
APPINIT_DLLS
and delete the default valueSource: Fixing "the application was unable to start correctly (0xc0000018)" in Windows - gHacks Tech News
http://www.ghacks.net/2015/10/16/fixing-the-application-was-unable-to-start-correctly-0xc0000018-in-...
