Error when want publish panel at web by using Web publishing tools.
You marked your own reply as the solution?  How did you solve it?
Did Adnan's link help you?  If so, mark that as the solution.  And if so, exactly how did it help you?
It can't be that the VI was not actually in memory, because in your response to me, you said you had it running.
It can't be that the web server wasn't enabled because you got served up a webpage.
Message 11 of 14
(593 Views)
Ya, I solve it already.
The Adnan's link helped me.
In response to you, I said is LabView program runnig, not my VI runnig. If I know your meaning early, that is must open my VI first, I already can slove this problem.
But anywhere, thank you for your helpping. Your information also help me more.
Message 12 of 14
(587 Views)
Then please mark Adnan's reply as the solution, not your thank you note.
I did say "Is the VI running on the server computer?"  I don't know how you confused that with "Is LabVIEW running on the server computer?"
I'm glad you have it worked out.Smiley Happy
Message 13 of 14
(569 Views)
Thanks your remind.
Change already, mistake.
 :smileywink:
Message 14 of 14
(560 Views)
