Error when building FPGA build specification using labviewCLI
Hi.
I have a labview project with a sbRIO real-time target. I can successfully build both the real-time application and the fpga using their respective build specifications. However when I try to build it from the command line (setting up a script for continous integration), the FPGA build fails with the following error:
Error Code : 1370
Error Message : mxLvErrorHandler.vi:2660001
An error occurred while running the ExecuteBuildSpec operation.
This is the command I try to execute:
"labviewcli.exe -OperationName ExecuteBuildSpec -ProjectPath "C:\labview_CI_test\lv_ci_test_rt\utilities\build_scripts\..\..\src\lv_ci_test_rt.lvproj" -TargetName "FPGA Target" -BuildSpecName "FPGA""
I know that the paths and target names etc. resolves correctly as if I change any of them I get more descriptive file not found errors.
Anyone know what the problem might be?
System info:
LabVIEW 2020 SP1 32-bit
Windows 10
(1,624 Views)
Hello oakl,
This thread is a bit old but I am encoutering the same problem. I am trying to build a fpga dummy project to see if we could include the fpga build process in our CI.
I tried with the following command:
LabVIEWCLI -OperationName ExecuteBuildSpec -ProjectPath "C:\Users\LCLMATCUST\Desktop\testFPGA\testFpga.lvproj" -BuildSpecName main -TargetName "FPGA"
and received the following error :
LabVIEWCLI started logging in file: C:\Users\LCLMATCUST\AppData\Local\Temp\lvtemporary_346158.log
"LabVIEWPath" command line argument is not passed. Using last used LabVIEW: "C:\Program Files (x86)\National Instruments\LabVIEW 2019\LabVIEW.exe"
Connection established with LabVIEW at port number 3363.
Operation output:
Error Code : 1370
ExecuteBuildSpec operation failed.
Have you found a solution to this issue?
(1,119 Views)
I think building in LabVIEW FPGA is a different call (see how it is in VI Server) than it is with LabVIEW for Desktop (windows).
There are 'hidden gems' in the RVI folder of LabVIEW.
ALE Consultants
(1,110 Views)
Hi Terry,
I thank you for your message. I have found this article in the knowledger base
Programmatically Build / Replicate FPGA Build Specification and Automatically Launch Compilation - N...
Looks like I could try to use niFpgaBuild_GenerateCode and niFpgaBuild_Compile to try to build something that would be able to build and manage the result. I have also asked the NI support if they have something more official to support this use case. If I come to something interesting, I will repost here.
(1,107 Views)
Here I could manage to have something that could work. But I don't know for how long since we are not supposed to use directly some of the used VIs.
In appendix I have joined a projet called testFpga.lvproj with a dummy fpga vi that juste do a simple calculation (main.vi).  In the "My Computer" target there is a vi called fpgaAutoBuild.vi that used two vi that every installation of labview should include. I have set the connector pane as documented here (RunVI - LabVIEW Wiki) to allow the vi to be execute from the Labview CLI.
The following command should launch the build process of the fpga vi
LabVIEWCLI -OperationName RunVI -VIPath "Path to fpgaAutoBuild.vi" "path to testFpga.lvproj" FPGA main
Hope this example will help
Arnaud
(1,098 Views)
