03-31-2021 05:28 PM
I'm attempting to use the VIPM for LabView Community Edition on my Mac OS Big Sur.
I was able to get LabView up and running, as well as install the VPIM
I'll post the error log here - anyone have any bright ideas?
I did look in the location of the file specified and it was not there. I don't want to go adding stuff, and possibly make matters worse.
Has anyone seen this before - Thanks - Glen
=========== START of VIPM 2020.3 (build 2540) Error Message ===========
An internal VIPM 2020.3 (build 2540) Error has occured on: Wednesday March 31, 2021 at 05:49:48 PM
= Automated Message Start =
Error 7 occurred at Open VI Reference in 4CAE87077DA90CCADB21E5773689EC3C->OGPM
Class.lvlib:7C080BEA1EC19662B5DA3C06CFC740C3->OGPM
Class.lvlib:4E437D33561025421EDB976E7004C657->8899BC0D088CF516BD12A96A34A12572->VIPM Main Window.vi
Possible reason(s):
LabVIEW: (Hex 0x7) File not found. The file might be in a different location or deleted. Use the
command prompt or the file explorer to verify that the path is correct.
VI Path:
/private/var/folders/w7/rtz9k1m114390vq0fxc21bv00000gn/T/AppTranslocation/C86EDFB1-D3E5-4FA3-8D66-0E
CC9F60F74F/d/VI Package Manager.app/support/callbacks.llb/Refresh Menus 2013.vi
= Automated Message End =
= User Defined Message Start =
Post Package Task Errors
= User Defined Message End =
= Error Handler Call Chain Start =
VIPM Main Window.v
= Error Handler Call Chain End =
=========== END of VIPM 2020.3 (build 2540) Error Message ===========
03-31-2021 10:27 PM
LINX is installed automatically with my Windows version of LV 2020 CE. That is not the case for Mac?
04-01-2021 01:22 PM
Hi Bill - I see on some places that is the case. However, I looked at the menu and I do not see that.
If you look on my dropdown menu, I do not see the menu item.
/Applications/National Instruments/LabVIEW 2020 64-bit/vi.lib/ also, I do not see the MakerHub directory in the directory.
ls /Applications/National Instruments/LabVIEW 2020 64-bit/vi.lib/
So, did I forget something during the install?
Glen
04-01-2021 05:29 PM
I doubt you did anything wrong. You should have a LINX palette for your block diagram if it's installed correctly. I need to go home and look at my (Windows) setup to see if it appears in the tools menu, though. I don't remember seeing it there, but like I said, I have to go home and confirm it.
04-02-2021 12:42 PM
Hi there - thanks again for responding.
Ever notice that when you offer someone help, they never leave you alone? 😎
Hey, did I mention that I was running on a Mac - Big Sur? I noticed that this OS seems to have all sorts of incompatibilities with things. I had a bitch of a time getting stuff like VirtualBox and in this case LabVIEW running. I should just stop being a cheapskate and buy a license. However, I don't really need it, except for support.
Anyway, would you recommend any good resources, besides the obvious, for me to dig into LabView - it's been many years since I used it and I have forgotten about lots of it's features.
However, I would still like to resolve this part - thanks.
Glen
04-02-2021 05:40 PM
I tried something else.
I went into my System Preferences on my Mac and made sure that LabVIEW and VIPM has access to the disk (r/w)
I'm still getting the errors - this doesn't make much sense to me.
The VIPM error is as follows:
Main Package Name: MakerHub Toolbox v2.0.0.35
Package Name with Error: MakerHub Toolbox v2.0.0.35
Error Message: VIPM could not install the package lvh_toolbox-2.0.0.35 .
Error Code: 7
Error Source: Write to Text File in Command-Line Zip.lvlib:ABDDB5E9F4D44AE0E70A4E4F8D4F491A->90BBE5FF7A35F3CE3E236F5A778C7C48->AD4791BDA0231EB30EBF129C1A98AB7B->OGPM Class.lvlib:1D42A1CCBC79EB157F4B29421C6C7648->OGPM Class.lvlib:68DD1F408D6154AB6D8715845077EEA9->FB296AD1654D68D63B7041E1F06FA55C->VIPM Main Window.vi<APPEND>
/Applications/National Instruments/LabVIEW 2020 64-bit/vi.lib/MakerHub/Toolbox/LMH-Toolbox.lvlib
Main Package Name: Digilent LINX (Control Arduino, Raspberry Pi, BeagleBone and more) v3.0.1.192
Package Name with Error: Digilent LINX (Control Arduino, Raspberry Pi, BeagleBone and more) v3.0.1.192
Error Message: VIPM could not install the package lvh_linx-3.0.1.192 .
Error Code: 7
/Applications/National Instruments/LabVIEW 2020 64-bit/vi.lib/MakerHub/LINX/LMH-LINX.lvlib
An internal VIPM 2020.3 (build 2540) Error has occured on: Friday April 02, 2021 at 06:26:26 PM
Possible reason(s):
VI Path:
/private/var/folders/w7/rtz9k1m114390vq0fxc21bv00000gn/T/AppTranslocation/54274253-33FC-46D0-A566-B7
F86CC7D1F7/d/VI Package Manager.app/support/callbacks.llb/Refresh Menus 2013.vi
VIPM Main Window.v
Now, this may be a clue - it seems that any package that I attempt to install with this, I get the same type of error. Error code 7.
So, think that would help at all?
Thanks - Glen
04-03-2021 12:55 PM
Dang, I forgot to get back to you!!!
As LINX is officially part of LV 2020 CE, you should have an entry named "LabVIEW Hobbysist Toolkit" version 20.1blahblahblah in NIPM (not VIPM!). Mousing over the entry confirms that this is the LINX toolkit.
04-03-2021 12:57 PM - edited 04-03-2021 01:02 PM
Please stop trying to install the old version from VIPM. I don't know, maybe it already screwed up your install and you need to re-install the toolkit I mentioned in the post above.
Edit:
I don't know if Mac has NIPM; look wherever you look to see if LINX was installed and look for the Hobbyist Toolkit instead.
04-03-2021 01:06 PM
Also, check your block diagram palettes for a "Hobbyist" palette.
04-03-2021 06:28 PM
FWIW, when I first installed LV 2020 CE I too used VIPM to try to add LINX & MakerHub toolkits. I ran into a lot of errors through those attempts, came to the forums to search around, only to find that shouldn't have needed to install those toolkits manually through VIPM at all. By that time however, removing the unnecessary VIPM packages didn't solve things for me either.
Eventually I just did an uninstall / reinstall of LV 2020 CE, after which the built-in LINX support functioned properly. If all else fails, maybe that'd be worth a try?
-Kevin P
