Error handling: Customizing error details: Info about the the path to the VI which has thrown the error
I need a quick advice about how to display in the error cluster the information about the path and VI which has thrown an error.
When I don't prepare my own error message, and the error is captured automatically, the information about the path, Vi name and calling VIs is presented automatically.
When I prepare/define my own basic error cluster I have only what I define in the string part of the cluster.
How to cause tha apperance the path and VI name in my defined error message?
Message 1 of 8
(2,703 Views)
Are you talking about the custom error code node, or building your own error clusters from scratch?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(2,694 Views)
From scratch, as below
but I'm open for suggestions.
Message 3 of 8
(2,691 Views)
Either use the Error Cluster From Error Code VI, or look inside it to see how it works.
Message 4 of 8
(2,672 Views)
Use an error ring
You'll feel a lot better in the morning
"Should be" isn't "Is" -Jay
Message 5 of 8
(2,631 Views)
@MimiKLM wrote:
You mean this link
That's helpful too but,  I had read "When I prepare/define my own basic error cluster I have only what I define in the string part of the cluster" as you wanted to use a file to expose those custom error codes and ultimately ship them with your solution dynamically rather than statically
The error ring will pick up any custom errors you define in the error file(s).  Including formatting!  this then populates the explain errors and error dialogs just like any error definition that ships with any LabVIEW component or toolkit.
Certainly, an error ring can also STATICALLY define or re-define an error within the application instance the ring is called from.  Those Error Rings are quite flexible!
Message 7 of 8
(2,590 Views)
Yes but the link yo sent is nor valid. 404
Message 8 of 8
(2,578 Views)
