07-04-2017 08:34 AM - edited 07-04-2017 08:53 AM
My problem is that when I install DSC (datalogging supervisor control) module error, indicating that I must first install LabVIEW 2017, but I already have LabVIEW 2017 installed and I do not know why I can not install it.
Mi problema es que cuando ejecuto la instalación del módulo DSC(datalogging supervisor control) sale error, indicandome que primero debo instalar LabVIEW 2017, pero yo ya tengo instalado LabVIEW 2017 y nose porque no puedo instalarlo Ojalá me ayuden porfavor es urgente gracias
07-04-2017 08:47 AM
hi,
i don't speak <YOUR LANGUAGE> but the error suggests you need labview 2017 installed first.
and please DON'T attach images that are 4MB
regards
07-04-2017 08:51 AM
07-04-2017 09:04 AM
could it be that you have mismatching architectures (64bit labview and 32bit DSC .. or the other way around?)
see this thread https://forums.ni.com/t5/LabVIEW/can-t-install-Datalogging-and-Supervisory-Control-Module-2014/td-p/...
07-04-2017 10:06 AM - edited 07-04-2017 10:09 AM
I have 64-bit labview installed and 64-bit DSC too but I can not install DSC
07-15-2017 11:48 PM
Revisa que al momento de instalar DSC module la ruta de instalación sea la correcta, es decir que este en las mismas carpetas en tu disco duro.
09-11-2017 12:05 AM
