03-02-2009 11:42 AM
On a second system where I apparently do not have a VISA driver correctly installed, I receive an error: "Driver Status: (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.".
This error is not a concern for the issue I'm reporting here; however, it appears to have a causal effect that I do not understand:
After this error occurs, the application appear to stop processing events; that is, there is an event structure that no longer seems to function and I can find no place where the application is looping. It simply appear to stop normal processing even though it is in a "run" status.
There is an Simple Error Handler.vi that pops up a dialog that indicates the error mentioned above; when I place a break on the error in to this VI, continue the application at the break, press ok on the error handler, the follow-on hang does NOT occur.
So all I need to do is disable the breakpoint and the hang condition re-occurs. So apparently, the "break" is somehow prevent an undesirable event processing disable or something like that. Breakpoint before the Simple Error Handler.vi, everything behaves as expected, breakpoint disabled, events become disabled. I tried putting a 500ms delay via stacked sequence before the Simple Error Handler to see if a race condition existed - no effect.
Any clues? I can work around this as it only occurs in my "offline" development system, but it's an interesting issue that I'd like to solve.
03-03-2009 08:08 AM
HI
Can you please upload the VI?
Regards
Santosh
03-03-2009 08:53 AM
Does this problem only occur on the system that does not have VISA properly installed? What LabVIEW version is this? This is important to see if anyone else has had similiar problem. Thanks.
03-03-2009 11:12 AM
Yes, this occurs on the system where a driver is incorrectly installed. LV 8.6. Unfortunately, the VI is far too large and proprietary to upload. It's not high enough priority to duplicate at a smaller level at this time.
If there's any way to see what LV is doing when in this "events disabled" state, or re-enabling events, I'd be interested in learning how to do that.
03-04-2009 11:31 AM
03-04-2009 11:47 AM
03-04-2009 11:59 AM
