Error Warning 1073676294, wont end my program
Hi all, I have counter this error warning 1073676294
I am fully aware it is not an actual error, but some thing to do with bytes transferred etc.
However it causes my program to not closing, after it is done, and it will stuck at the close.vi
and flashing red and light blue color at the border.
and not ending the program, it will cause issue for the user.
How do I make the program close, despite the warning.
i have tried exception code at the error handler, doesnt work :<
Seng
(243 Views)
Accepted by Noob_intern
Have you tried Clear Errors?
=== Engineer Ambiguously ===
(227 Views)
Thank you for the fast reply.
I tried placing it at 2 different spot, both results the same.
The errors are removed, no warning message.
But the program still wont close by itself , it will just start blinking red and blue border
This problem doesn't exist at individual VI,
it happens when i put the VIs into one program with a sequence of testing
(225 Views)
Thank you !
it works in removing the error!
The red border is breakpoint that I accidentally turn on, and unaware of !
Seng
(215 Views)
