06-20-2006 01:53 PM
06-21-2006 11:51 AM
What version of LV PDA module are you using? If I am correct, you are probbaly using LV PDA 7.1 or 8.0, none of which support Win CE .NET 4.2. You would need to use LabVIEW PDA 7.0 in order to use it with a PDA running Win CE.NET 4.2 OS.
Ankita
06-21-2006 12:35 PM
06-22-2006
05:32 PM
- last edited on
12-02-2025
11:20 AM
by
Content Cleaner
The best place to get started with the requirements is the datasheet. You can also find the information in the PDA module manual.
I’m not convinced that a previous post was correct (http://forums.ni.com/ni/board/message?board.id=170&message.id=160316&requireLogin=False). Have you seen this tutorial for Windows CE?
I apologize for the confusion! Please review these documents and let me know if you have any additional questions.
