Error: Hex 0xBFF60492
Hello together,
I wanted to use a Sanyo Xacti CG 10 video camara in LabView.
By using the NI-IMAQ for USB Snap I get the following error: IMAQ Vision: (Hex 0xBFF60492) Ungültige Blit-Funktion des Videoausgangs.
Is it possible, that I can not use this camera in LabView?
Driver are up to date for the camara and IMAQ.
Thanks a lot for your reply
(3,206 Views)
Hey KvonK,
some further information would be helpful for me and the other people in the forum. Can you see the camera in MAX? Is it possible to get a picture from the test panel in MAX?
It would also be very helpful, if you post the used VI.
And because I understand the german error text: Is "Blit-Funktion" the real error message text or only a typing error?
Regards, Stephan
(3,165 Views)
Hello Stephan_D,
thank you for your answer.
I can see the camera in MAX and it I can see the video directly (Attachment)
The name of the used VI is "NI IMAQ for USB snap_VBAI stab.vi".
The error which I get with this VI is :"IMAQ Vision:  (Hex 0xBFF60492) Ungültige Blit-Funktion des Videoausgangs.".
I tried it also in the NI Vision Builder, but there I get only the mistake "No NI-ImaQdx Camera Connected".
I hope you can help me.
Best regards
Christian
(3,153 Views)
Accepted by topic author KvonK
Hi Christian,
please try to acquire a image with the attached VI. Do you also receive a error message with this programm code, if you choose your USB Sanyo Xacti CG 10 and run the VI?
Regards, Stephan
(3,137 Views)
Hello Stefan,
thank you for your reply.
With this VI I am able to get the video from the Sanyo Xacti CG 10 into LabView.Smiley Happy
In this way I can proceed the data in my way.
Best regards
Christian
(3,124 Views)
