Error Code during repair - Error 1618 occurred
I am having trouble loading/deleting/installing my Labview devices and drivers.  These are the February 2006 updates.
Disc 1 loaded no problem. After disk 2 was loaded, it sat an spun in the drive for 20 minutes.
Noe when I go to the control panel> Add remove programs and try to repair or remove the software I receive an installer error window that says Error 1618 occurred. Would you like to continue the operation?
Any hints on removing all of NI software so I can perform a reload?
Warmest Regards,
Bill
(6,354 Views)
I was trying to remove all programs at once. One at a time did the trick
(6,346 Views)
Happened to me too when i tried to uninstall Labview. I had another instalation running in background after instalation finished it was OK.
(5,494 Views)
Hello LabView professionals,
I am having significant issues with the various versions of LabView RunTime. I need to install version 7.1 of the runtime because a product my company purchased runs on that version. So I tried to install it, but the installer just hung. Now I am trying to remove the 2011 Run-Time I had installed so as to clean up my computer, but I keep getting this error 1618 referred to in this thread. I am not able to remove the run-time from my computer.
I am evaluating LabView for our company, unfortunately the complexity of the runtime environment, poor error handling, and installer issues, is not allowing me to move forward. Please help.
Thanks for reading.
Carlos F
(5,124 Views)
I recommend you start a new thread and reference this forum as something you have already viewed. Newer threads (especially ones with only one post) get more notice and responses from users
Cameron T
(5,116 Views)
