Error -- Block Diagram is Completely Black
I've been working on a relatively complicated .vi that has a good amount of case structures and flat sequences.  As I was testing the front panel and going back and forth between the block diagram, the block diagram became entirely black -- all I see is a black background -- no wires, blocks, etc.  I am still able to add blocks through the menu but can't actually see them being placed or anything.  Is there a way to fix this, or revert back to normal?  I would really not like to redo all this work...
Bryan
(4,669 Views)
I am able to run the .vi operate it using the front panel as if nothing is wrong,  I'm just unable to edit the block diagram.
 I just Ctrl+A'd the block diagram and pasted onto a new .vi -- block diagram is back to viewble/normal!
(4,665 Views)
I think there are some unusal observations of you exceed a certain diagram size ( e.g. 16000 (?) in pixels). How big is your diagram?
(Other possibilites are issues with your video card, graphics driver, or color depth setting of the OS.)
(4,662 Views)
It must be hardware problem. your problem looks interesting though.
(4,634 Views)
The diagram was pretty big -- there was an errant label at the very bottom.  Dimensions were about 16000 x 1000.  Made it much smaller (about 2000 x 1000), so hopefully there won't be any issues like this any time soon.  Also if anyone was wondering, restarting LabVIEW or my computer did not solve the problem...the only thing I could figure out was to ctrl+A and copy everything to another .vi.
Thanks.
(4,619 Views)
You are aware of that it is possible for you to make subvi's?
That will help you reduce the size of the block diagram for you vi's.
What is a good amount of case structures and flat sequences?
Use of Flat sequences diagram screams of insufficient use of dataflow.
(4,593 Views)
A good amount of case structures and flat sequences is 0-2 and 0-1 respectively (in a single .vi). 😉
(there's exceptions to every rule, but if you need more, you probably need more sub vi's)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,530 Views)
