05-11-2019 03:56 AM - edited 05-11-2019 03:59 AM
Hi there!
I have a problem when I am using the myRio. Previously. I can run the program "main.vi" but in this part when I am using myRio-1900 (.lvproj), I can not run the program. The error code is 7
I also attached the picture of the program. I am using LabView 2018
Please Help Me,
Thank You,
Intho N Syuhri
Master Student Electrical Engineering
Solved! Go to Solution.
05-11-2019 09:46 AM
Is this VI running on your RIO?
The file path control looks like a Linux type file path. It is pointing to a D drive. And a "Documents" (?) folder on that D drive. Do you have that path on your RIO? To me it sounds like a path you'd find on a Windows PC.
Your RIO can only access files on its own drive, it can't access files on another device.
05-11-2019 11:06 AM
Perfect,
Yes, I need to save ".fs" file into myRio directory.
Thanks a lot.
Intho N. Syuhri
