Hi all,
I am on a field campaign with my Labview-controlled instrument. I wanted to make a small change to the code and build it again for uploading to a cFP-2020 Fieldpoint but the application builder stopped with the following error message:
Error 7 occurred at ABAPI Dist Report Read Link Info Error.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File2.vi -> ABAPI Get Settings From File.vi -> RTBEP_Invoke_Build_Engine.vi -> RTBUIP_Build_Invoke.vi -> RTBUIP_Build_Invoke.vi.ProxyCaller
This is another computer than the one I used in the lab previously so might have forgotten to install something. I just copied the whole application folder with project file and subfolders
to the Laptop I am using now. Labview version should be the same though (8.20).
Any suggestions?
Olaf
