Error 6 sometimes with TDMS Defragment VI (LV 8.2) (WinXP)
I sometimes get error 6 when I run the TDMS Defragment VI. This VI is run in my program right after I close the file after writing it (to a network drive). Could that be the problem? Does the file need time to close before the defrag is started? If so, is there any way to know when the file is ready?
George
(3,394 Views)
Hi George,
I could not reproduce this error with the tdms file saved either on a local drive or network drive. I will suggest testing the VI with the tdms file on the local drive. You can also place a flat sequence structure with time delay (100ms) between the TDMS Close and Defragment VIs.
Tunde
(3,376 Views)
Yeah I thought about adding a time delay, but unless I know for sure what's causing the problem it's hard to know if that's always going to work.
George
(3,365 Views)
