02-11-2019 04:44 AM
We are trying to acquire the Frequency difference data from Symmetricon 5115A instrument using TCP/IP protocol in NI LabVIEW.
(For your information ,Instrument is directly connected to the host PC so there is no need to have server-client application)
Aim of the project is to acquire and record the Frequency difference data every second .
Issue : On giving 1000ms sec delay in the while loop (as shown in the attachment) , we are getting ERROR 56 at TCP WRITE. .
We have tried to clear the error and re-establish the connection using the state machine , But this process is taking around 2 minutes , which is not needed for the application .
Kindly give suggestion for the continues acquisition of the data without error or any break.
Thanks in advance
Azhar
02-11-2019 05:56 AM
Are you sure your instrument ends a message with both a Carriage Return (CR) and a Line Feed (LF)? You and ending your messages with just a line feed. So either you are sending the message wrong or you are trying to read it with the wrong termination. Based on what I am seeing in the code, I would switch to using VISA to talk to your instrument and be sure to have the termination character set to Line Feed (0xA).
02-13-2019 05:41 AM
Thank you very much for the quick response.
I am attaching the screenshot of the vi with ("\") code display, It is showing \r\n in the output, Does it mean instrument is sending EOL character?
Also, I am attaching , the screenshot of NI MAX settings of VISA test panel for your reference.
I have tried to replace the Line feed character to EOL character in TCP write command in LabVIEW GUI but still getting the same ERROR 56 .
Also , I tried to concatenate the command with both Linefeed and Carriage Return character in TCP write command , that also gives the same ERROR 56.
Kindly suggest me , if there is any need to modify settings in the NI -MAX or in NI LabVIEW GUI.
Also, The settings in the instrument is not configurable for the termination character.
Thanks in Advance!
Azhar
02-18-2019 05:44 AM
We are getting Error 56 at the TCP write .The instrument Symmetricom 5115A Phase Noise Test set up is directly connected to the host PC.
For your information :
I am attaching the screenshot of VI , Kindly suggest possible solution .
Azhar
02-19-2019 10:51 PM - edited 02-19-2019 10:57 PM
Kindly help me with the possible solution.
Thanks in advance,
Azhar
02-19-2019 11:56 PM
We are Communicating the instrument "Symmetricom 5115A" using TCP IP protocol . The instrument is connected directly to the Host PC and Firewall of PC is OFF.
In NI-MAX , we found that instrument is returning both LF and CR in the incoming message when , we set LF as termination char at NI VISA test panel.
But when we try to write LF as termination char in the VISA property node , it is showing error -1073807331 at the VISA property node as shown in the attached picture.
Also, while acquiring data of through command "show freqdiff" , it is showing ERROR 56 at TCP write. , We tried to clear the error and reestablishing the TCP connection , but this process is taking more than 2 minutes which is undesired in our application
Kindly suggest possible solutions.
Thanks in advance
Azhar
02-20-2019 12:10 AM
As suggested by you:
Thanks in advance
Azhar
