03-28-2023 03:06 PM - edited 03-28-2023 03:09 PM
I have a program containing a main VI with multiple sub VIs. The main purpose of the program is to collect electromyogram data from a varying number of muscles (1 or more input channel during usage). When I run the program using a physical DAQ and collecting 32 channels of noise data at 10 kHz, the Error -50808 appears (below) after a specified period of time. On my laptop, the error appears after ~550 seconds, while on my desktop, the error appears after ~1k seconds.
I searched ni.com for the error, which states to turn off USB port sleep. I did what the post suggests, and the error still appears.
Is this a memory overflow error? What else would be causing this error regarding USB transfer to appear? It's like I unplugged the USB DAQ input during program usage, which of course I did not do!
Also, this error does not appear when using a simulated DAQ, only with a physical DAQ!
Thank you so much in advance!
