Error -50150 "Cascade Failure": LabVIEW Bug?
I'm new to the forums here, so I apologize in advance for breaches of etiquette or various other newbie actions. 😉
While using the DAQmx Create Channel VI in conjuction with my own custom unit scale, I keep running into a -50150 error for various combinations of slope and y-intercept. I've pared my problem down to the attached VI. As you can see, I'm setting up the linear scale with a slope and y-intercept, and then scaling the original +/- 10V range for an appropriate maximum and minimum. Upon running this VI as-is, I get the -50150 "cascade failure" error. However, changing the y-intercept value to an arbitrarily different value, say 6, causes the program to run fine.
I've noticed that other combinations of slope-intercept also crash the program, and that these combinations usually have a pattern. For example, the (m, b) combinations of
(100,5); (100,20); (100,30); (100,45); (100,55); (100,70); and so on, with the 10-15-10-15 pattern repeating
cause the program to throw -50150 as well. I have not found any values of the y-intercept that cause the program to crash that are not multiples of 5 (although obviously I cannot say conclusively that there are none). I realize that it is all very well for me to claim that this is a software bug and not my fault, but I cannot see any good reason for this to be happening in such an odd way.
I am running LabVIEW 8.2.1, DAQmx 8.5, WinXP SP2, Pentium 4 2.79 GHz, 768 MB of RAM. The hardware involved is an NI cDAQ-9172 chassis with NI 9205, 9263, 9211, and 9211 modules in slots 1, 2, 3, and 4, respectively. Thanks very much for your time.
(3,262 Views)
Hello Paul,
This was reported to R&D (# 4C0IH7AH) for further investigation.
As a workaround, you can change the 10 and -10 limits to something very near to 10 and -10, like 9.99999 and -9.99999. This seems to resolve the issue and will result in basically the same limits. I have attached a modified VI that demonstrates this change. Thanks for the feedback Paul!
Matt Anderson
Hardware Services Marketing Manager
(3,224 Views)
I think I was secretly hoping for a problem on my end; it seems to add more closure when someone tells me I am wrong. 😉 Luckily, the posted workaround works fine for our purposes.
Thanks, Matt!
(3,206 Views)
